The most powerful, the working program for remote administration of Windows, allows you to work effectively on several remote computers using conventional graphical user interface.Along with support for NT security model and localization in any language can work in file-sharing regimes, and Telnet, which allows Radmin seen as an integrated solution for remote management of any scale.
Features:
»Full compatibility with Windows Server 2008 (32-bit and 64-bit)and Windows Vista SP1 (32-bit and 64-bit)
»Unparalleled speed
»The highest level of security
»Multiuser text and voice chats
»Support for multiple monitors
»Ease of Use
»Drag-and-Drop for records and folders
»Low system requirements
»Support for multiple connections
»Free Technical Support
Operating system:Windows ® 2000/XP/Vista
Download:
http://rapidshare.com/files/222135020/1398RADMINP.rar
