Windows Admin Sifresini Kirmak (Sifirlamak)
Windows Password Expert 1.2
Windows 2000 /XP/ 2003 sifrelerini sifirlamak icin kullanilan bir yazilimdir
Download:
http://w13.easy-share.com/1699354961.html
http://depositfiles.com/files/3434469
5.kural
Kayıt: 15 Nis 2008, 12:00
Mesaj gönderen 5.kural »
Tesekkür ederim elinize saglık
OphCrcak ile windows sifresi kirmak (videolu anlatim)
ophilaç livecd-1.2.2 versiyonu. 455.24mb
Download:
http://superb-east.dl.sourceforge.net/sourceforge/ophilaç/ophilaç-livecd-1.2.2.iso
izle:
http://www.youtube.com/watch?v=6JWCF-4Ma7A
editci
Megabyte3
Megabyte3
Kayıt: 06 Nis 2006, 16:30
Mesaj gönderen editci »
denedim. operasyon basarılı. eline saglık. :)
Passware W!nd0w$ Key Enterprise Edition
Passware W!nd0w$ Key Enterprise Edition v8.3.2867 Bootable CD RetaiL
W!nd0w$ Password Recovery Key Enterpriese - unlocks Administrator account, resets active directory passwords
Features
>> 100% recovery rate
>> All passwords are reset instantly
>> W!nd0w$ Vista, Vista SP1 supported
>> All W!nd0w$ Workstations supported
>> All W!nd0w$ Servers supported (W!nd0w$ Key Professional and Enterprise versions only)
>> Resets passwords with a bootable CD-ROM
>> Resets passwords with a bootable USB drive or driver floppy (W!nd0w$ Key Professional and Enterprise versions only)
>> Burns password reset CD
>> Resets local Administrator passwords
>> Resets Domain Administrator passwords (W!nd0w$ Key Enterprise version only)
>> Resets local policy settings
>> Resets secure boot options: startup password or startup key disk
>> Displays account properties
>> Supports all Service Packs
>> Supports RAID/SCSI/SATA drives Updated!
Download:
http://rapidshare.com/files/121430000/Passware.W1nd0w5.Key.Enterprise.Edition.v8.3.2867.Bootable.CD.Retail-ZWT.rar
http://w17.easy-share.com/1700595925.htm
l
Pass:www.softarchive.net
Videosu:
http://www.ogren.tv/dersler/kullanici-s ... kirma.html
Reset any windows password(including Vista)
Forgot your Windows Admin/User password? Want to find out your computer's BIOS/CMOS password? This is the right tool for you! Works on USB drives too so no need to burn unto a CD.Big things come in small packages!
Download:
http://rapidshare.com/files/135884493/delete_xp_vista_login_password_works_perfectly.rar
8 Mb lik asagidaki dosyayi CD ye yazdirip , sonrasinda Sisteminizi bu Cd ile baslatip sifrenizi 12345 sekline getirebiliyorsunuz
http://rapidshare.com/files/16489653/WindowsKey.iso
adrianfire
Kayıt: 01 May 2008, 21:26
Mesaj gönderen adrianfire »
cok güzel bir çözüm
drog_1
Megabyte3
Megabyte3
Kayıt: 15 Mar 2006, 16:40
Mesaj gönderen drog_1 »
CIA Commander'in lisanslı olanını bulabilen var mı
Reset Any Windows Password
Download:
http://rapidshare.com/files/155238881/w.passd.resetby_ewares.org.rar
sadece Cd ye yazdirip CD den boot edin
Re: Windows Admin Sifresini Kirmak (Sifirlamak)
Active@ Password Changer 3.5.0128 Corporate
Active@ Password Changer 3.5.128 Corporate | 2.42 MB
Released: October 29, 2008
Active@ Password Changer is designed for resetting local administrator and user passwords on Windows XP / VISTA / 2008 / 2003 / 2000 systems in case an Administrator's password is forgotten or lost. You do not need to re-install and re-configure the operating system.
Forgotten password recovery software has a simple user interface, supports multiple hard disk drives, detects several SAM databases (if multiple OS were installed on one volume) and provides the opportunity to pick the right SAM before starting the password recovery process. It displays a list of all local users. The software user simply chooses the local user from the list to reset the password.
Other Windows login security restrictions like 'Account is disabled', 'Password never expires', 'Account is locked out', 'User Must Change Password at Next Logon' and 'Logon Hours' can be changed or reset.
With Active@ Password Changer you can log in as a particular user with a blank password.
Download:
http://rapidshare.com/files/159070740/Active.Password.Changer.Professional.v3.5.128-DOA.rar
http://kewlshare.com/dl/a967090dcf3a/Active.Password.Changer.Pro.v3.5.Build.0128.Incl.Serial.zip.html
http://kewlshare.com/dl/a91ecde02a8d/Active.Password.Changer.Pro.v3.5.Build.0128.Incl.Serial.zip.html
http://rapidshare.com/files/159880954/Active.Password.Changer.Pro.v3.5.Build.0128.Incl.Serial.zip
Active@ Password Changer Professional 3.5 Build 0277
Download:
http://rapidshare.com/files/140888081/pwchangerpro.rar
yada
http://rapidshare.com/files/184531366/PwCgr.rar
Pass:www.tsbay.org
yada
http://rapidshare.com/files/159274236/Active__Password_Changer_Professional_3.5.rar
Pass:www.warezraid.com
ERD commander linki yenilenmistir
Karabigalı
Byte1
Byte1
Kayıt: 14 Nis 2006, 00:46
Mesaj gönderen Karabigalı »
adminimmm süpersin :| unutulan sifreler için ideal.
Windows Admin Password Hack 2009
This is a utility to (re)set the password of any user that has a valid (local) account on your NT system.
You do not need to know the old password to set a new one.
It works offline, that is, you have to shutdown your computer and boot off a floppydisk or CD. The bootdisk includes stuff to access NTFS and FAT/FAT32 partitions and scripts to glue the whole thing together.
Will detect and offer to unlock locked or disabled out user accounts!
It is also an almost fully functional registry editor!
Windows Admin Hack allows you to reset the administrator password on
Windows 2000/XP.
The ISO must be burned to a CD or Flash drive.
When it is booted, a mini version of linux starts which allows the
administrator password to be reset. useful if you need to work on a
machine the password is unknown.
Download:
http://rapidshare.com/files/196167068/Windows_Admin_Password_Hack_www.dl4all.com.rar
Password:www.dl4all.com
Windows Administrator's Password C.r.a.c.k.e.r (Changer)|85kb
This Will sure work if You are not logged in as a limited user You don.t even need to ilaç anyone's password Just enter password and it will be changer
Enjoy!!!!!!!!!!!!!!
Download:
http://www.ziddu.com/download/3570067/Win_admin_pass_change_www.dl4all.com.rar.html
http://rapidshare.com/files/200253332/Windows_Administrator_s_Password_Cracker__Changer__100__working.rar
http://rapidshare.com/files/200254852/Win_admin_pass_change_www.dl4all.com.rar.html
