BT/IT Seviyesinden Network Reg Ayarları
Re: BT/IT Seviyesinden Network Reg Ayarları
denedim, maalesef sorun devam ediyor.xxozixx yazdı: ↑31 Mar 2024, 02:29teşekkürler, pazartesi günü işyerinde pc de deneyeceğim. sonucu pazartesi akşamı yazarım.burak35 yazdı: ↑30 Mar 2024, 01:01 @xxozixx merhaba. Kendi sistemime eklemeden önce ayarları varsayılan hale getiren bir reg kaydı hazırlamıştım.
Şöyle;Bunları sisteminize ekleyip dener misiniz?Kod: Tümünü seç
Windows Registry Editor Version 5.00 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Dnscache\Parameters] "NetFailureCacheTime"=- "NegativeSOACacheTime"=- "CacheHashTableBucketSize"=- "CacheHashTableSize"=- "MaxCacheEntryTtlLimit"=- "MaxSOACacheEntryTtlLimit"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters] "EnableICMPRedirect"=- "EnablePMTUDiscovery"=- "EnablePMTUBHDetect"=- "PerformRouterDiscovery"=- "EnableDeadGWDetect"=- "NoNameReleaseOnDemand"=- "SynAttackProtect"=- "KeepAliveTime"=- "TcpMaxHalfOpen"=- "TcpMaxHalfOpenRetried"=- "TcpMaxPortsExhausted"=- "TcpMaxConnectResponseRetransmissions"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters] "ForwardBufferMemory"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters] "DefaultTTL"=- "TcpMaxDupAcks"=- "SackOpts"=- "Tcp1323Opts"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\ServiceProvider] "DnsPriority"=dword:000007d0 "HostsPriority"=dword:000001f4 "LocalPriority"=dword:000001f3 "NetbtPriority"=dword:000007d1 [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Rpc] "MaxRpcSize"=- [HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\Ndiswan\Parameters\Protocols\0] "ProtocolType"=- "PPPProtocolType"=- "ProtocolMTU"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\Adapter ID] "MTU"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Lsa] "restrictanonymous"=dword:00000000 [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters] "TcpMaxConnectRetransmissions"=- "TcpMaxDataRetransmissions"=- [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters] "TcpTimedWaitDelay"=- [HKEY_CURRENT_USER\Software\Microsoft\MediaPlayer\Preferences] "PlayerScriptCommandsEnabled"=- [HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Win dows\Psched] "MaxOutstandingSends"=- "NonBestEffortLimit"=-
İndirme linkinide bırakıyorum.
https://www.mediafire.com/file/jrbu6vsi ... efault.reg
https://pixeldrain.com/u/TefCX8mq
Umarım sorununuz çözülür. İyi geceler.
- burak35
- Petabyte3
- Kayıt: 07 Eki 2016, 13:06
- Teşekkür etti: 3412 kez
- Teşekkür edildi: 3445 kez
O zaman yapabilecek pek birşey yok gibi. Belki kullandığınız başka bi yazılımdan,
Yada sistemde değiştirdiğiniz başka bi ayardanda sorun kaynaklanabilir. Çünkü günümüz windowsları biraz nazlıdır artık.
Ve neredeyse buluttan nem kapabilirler.
- Teşekkür etti: 4834 kez
- Teşekkür edildi: 4070 kez
Aşağıdaki iki kodu Yönetici olarak çalıştırılmış bir CMD den uygula bakalım etkisi olacakmı
reg add "HKLM\software\policies\microsoft\windows nt\Terminal Services\Client" /v fClientDisableUDP /d 1 /t REG_DWORD
reg add "HKLM\SOFTWARE\Microsoft\Terminal Server Client" /v "UseURCP" /t REG_DWORD /d 0 /f
- TRWE_2012
- Exabyte1
- Kayıt: 25 Eyl 2013, 13:38
- Teşekkür etti: 971 kez
- Teşekkür edildi: 2096 kez
Hayır var, yukarıda ekran görüntülerini attığım network portable yazılımlarından birini (favorim 1) kullanarak sorunu bir hamle de çözebileceğini düşünüyorum.
Ayrıca bu durum, benim verdiğim .reg ayarlarının bu olumsuz duruma yol açmadığını göstermekte..... Başka bir şey var gözden kaçan...
- burak35
- Petabyte3
Bencede başka yerde birşeyler var gibi. En azından bende öyle tahminediyorum.
Bende o ayarların hemen hemen hepsini parça parça elle oluşturup sisteme ekle kaldır yaparak denedim.
Tabi sisteme parça parça ekle kaldır yapmamdaki neden Windows 10 a tam olarak güvenememem.
"Uzak bilgisayara erişilemiyor. Bu sorun, kullandığınız ağın yapılandırmasından kaynaklanıyor olabilir." şeklinde mesaj veriyor. Ama bu ayardan önce aynı pc ye bağlanıyorum. Herhangi bir sıkıntı yaşamıyordum. İlla bu regedit ayalarından olmuş demiyorum. ancak benim endileştirenşu oldu bu regedit ayarlarında ağ ile ilgili sayarlar vardı, bunlardan olmuş olabilir mi diye sormuştum. Ayrıca, bu ayarladan sonra da işyeri güvenlik ayarlarında da değişikliklerde olmuş olabilir. Herkese çok ilgilerinden dolayı ayrı ayrı teşekkür ederim.
hocam cmd uzantılı dosyaları çalıştığımda McAfee virus programını virüs görüyor. Bu ayarları olursa regedit şekline dönüştebilir misiniz hocam.velociraptor yazdı: ↑03 Nis 2024, 11:46 Aşağıdaki iki kodu Yönetici olarak çalıştırılmış bir CMD den uygula bakalım etkisi olacakmı
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows NT\Terminal Services\Client]
"fClientDisableUDP"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Terminal Server Client]
"UseURCP"=dword:00000000
- burak35
- Petabyte3
Kullandığınız cihazları sizden başka kullananlar ve ayarlarını değiştirenler oldu mu acaba ?xxozixx yazdı: ↑03 Nis 2024, 23:27 "Uzak bilgisayara erişilemiyor. Bu sorun, kullandığınız ağın yapılandırmasından kaynaklanıyor olabilir." şeklinde mesaj veriyor. Ama bu ayardan önce aynı pc ye bağlanıyorum. Herhangi bir sıkıntı yaşamıyordum. İlla bu regedit ayalarından olmuş demiyorum. ancak benim endileştirenşu oldu bu regedit ayarlarında ağ ile ilgili sayarlar vardı, bunlardan olmuş olabilir mi diye sormuştum. Ayrıca, bu ayarladan sonra da işyeri güvenlik ayarlarında da değişikliklerde olmuş olabilir. Herkese çok ilgilerinden dolayı ayrı ayrı teşekkür ederim.
Birde içinde yada başında "Uzak" geçen hizmetleri kontrol edermisiniz?
Belki uzak masaüstü hizmetlerinden biri kapandıysa çalışmıyorsa ondanda olabilir.
Güzel yazı olmuş @TRWE_2012 eline sağlık. Yalnız aklıma takılan bir soru var. Bazı IT Güvenlik sitelerinde aşağıdaki ayarları şu şekilde yazmışlar:
LocalPriority = 4 (DWORD, the default is 499, change to 4)
HostPriority = 5 (DWORD, the default is 500, change to 5)
DnsPriority = 6 (DWORD, the default is 2000, change to 6)
NetbtPriority = 7 (DWORD, the default is 2001, change to 7) ve
TCPMaxPortsExhausted, TCPMaxHalfOpen, and TCPMaxHalfOpenRetried değerlerini 1 olarak belirtirken daha agresif bir zamanlama koruması için 2 değerini vermişler. Bunların arasındaki fark ne acaba? Onu merak ettim.
- TRWE_2012
- Exabyte1
O değerler Windows 7 ve sonrası için geçerli ve de donanıma özel değerleranonim23 yazdı: ↑05 Nis 2024, 18:11 Güzel yazı olmuş @TRWE_2012 eline sağlık. Yalnız aklıma takılan bir soru var. Bazı IT Güvenlik sitelerinde aşağıdaki ayarları şu şekilde yazmışlar:
Ama bendeki Windows XP için, donanımdan bağımsız değerlerdir.Aradaki temel fark da budur.
- burak35
- Petabyte3
TCPMaxPortsExhausted, TCPMaxHalfOpen, and TCPMaxHalfOpenRetried bunları windows 10 a eklememe gerek varmı acaba ?
- TRWE_2012
- Exabyte1
- burak35
- Petabyte3
Bu 3 dword HKLM\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters altına eklenecek dimi?
Eğer öyleyse bu 3 ünü britec in önerdikleriyle daha sonra sisteme ekleyeceğim.
