Ben şöyle bir kod yapabildim ama ip adresinide yazmak gerekiyor.
netsh int ip set address "Ethernet" static 192.168.1.72 255.255.255.0 192.168.1.1
Usage: set address [name=]<string>
[[source=]dhcp|static]
[[address=]<IPv4 address>[/<integer>] [[mask=]<IPv4 mask>]
[[gateway=]<IPv4 address>|none [gwmetric=]<integer>]
[[type=]unicast|anycast]
[[subinterface=]<string>]
[[store=]active|persistent]
Parameters:
Tag Value
name - Interface name or index.
source - One of the following values:
dhcp: Enables DHCP for configuring IP addresses for
the specified interface.
static: Disables DHCP for configuring IP addresses for
the specified interface. This value must be
specified if an address or a gateway is being
configured.
address - IPv4 address to add or modify, optionally followed by
the subnet prefix length.
mask - The IP subnet mask for the specified IP address.
gateway - One of the following values:
<IPv4 address>: A specific default gateway for the
static IP address you are setting.
none: No default gateways are set. This is the default.
gwmetric - The metric for the default gateway. This field should
be set only if gateway is specified.
type - One of the following values:
unicast: Marks the address as a unicast address.
anycast: Marks the address as an anycast address.
subinterface - LUID of the subinterface on which the default gateway
exists. This parameter is only needed on interfaces
with multiple subinterfaces.
store - One of the following values:
active: Set only lasts until next boot.
persistent: Set is persistent. This is the default.
Remarks: Used to enable or disable DHCP for IP address configuration.
Also removes any previous static IP addresses and default gateways,
and can add a new static IP address and default gateway.
Examples:
set address name="Wired Ethernet Connection" source=dhcp
set address "Wired Ethernet Connection" static 10.0.0.9 255.0.0.0 10.0.0.1 1
route change -p 0.0.0.0 mask 0.0.0.0 192.168.1.1
