This is basically an app to make Windows 7 explorer folder windows remember their size and position. It has a couple of additional features too, and hopefully some more later on. It does NOT manage window size/positions of regular applications, if you want that, other apps like Window Manager do it. Allthough I haven't tried it, in theory it should work to run Window Manager simultaneously, if it's configured to ignore folder windows (found as "CabinetWClass"). I'd strongly recommend configuring WM to ignore them, or disable WM, before running ShellFolderFix, to avoid any potential "fighting" between the two apps
dwnld
http://www.sevenforums.com/attachments/ ... xsetup.exe
x32 zip:
http://www.sevenforums.com/attachments/ ... rfix32.zip
x64 zip:
http://www.sevenforums.com/attachments/ ... rfix64.zip
Windows 7 - ShellFolderFix
- Teşekkür etti: 4592 kez
- Teşekkür edildi: 3908 kez
