Numara içeren dosya isimlerini doğru sıralama (Çözüldü)
Mendenn
Gigabyte2
Gigabyte2
Kayıt: 19 Haz 2006, 18:01
Mesaj gönderen Mendenn »
Aşağıdaki başlıkta önceden verilmiş. Burdaki reg kaydını kullanmama rağmen bir değişiklik olmadı.
Bende bu registry anahtarları altında bulunan değerler:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\Explorer
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies]
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoDriveTypeAutoRun"=dword:00000091
"NoStrCmpLogical"=dword:00000001
"NoInstrumentation"="1"
"NoLowDiskSpaceChecks"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Attachments]
"ScanWithAntiVirus"=dword:00000003
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Explorer]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\NonEnum]
"{BDEADF00-C265-11D0-BCED-00A0C90AB50F}"=dword:00000001
"{6DFD7C5C-2451-11d3-A299-00C04F8EF6AF}"=dword:40000021
"{0DF44EAA-FF21-4412-828E-260A8728E7F1}"=dword:00000020
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\Ratings]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System]
"ConsentPromptBehaviorAdmin"=dword:00000005
"ConsentPromptBehaviorUser"=dword:00000003
"EnableInstallerDetection"=dword:00000001
"EnableLUA"=dword:00000001
"EnableSecureUIAPaths"=dword:00000001
"EnableUIADesktopToggle"=dword:00000000
"EnableVirtualization"=dword:00000001
"PromptOnSecureDesktop"=dword:00000001
"ValidateAdminCodeSignatures"=dword:00000000
"dontdisplaylastusername"=dword:00000000
"legalnoticecaption"=""
"legalnoticetext"=""
"scforceoption"=dword:00000000
"shutdownwithoutlogon"=dword:00000001
"undockwithoutlogon"=dword:00000001
"FilterAdministratorToken"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\UIPI]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\UIPI\Clipboard]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\UIPI\Clipboard\ExceptionFormats]
"CF_TEXT"=dword:00000001
"CF_BITMAP"=dword:00000002
"CF_OEMTEXT"=dword:00000007
"CF_DIB"=dword:00000008
"CF_PALETTE"=dword:00000009
"CF_UNICODETEXT"=dword:0000000d
"CF_DIBV5"=dword:00000011
Teşekkür etti: 4563 kez
Teşekkür edildi: 3896 kez
Re: Numara içeren dosya isimlerini doğru sıralama (windows 7
https://www.sordum.net/3103/numara-icere ... -siralama/
üstteki başlığı diyorsun sanırım , peki Pc yi restart ettinmi ?
Mendenn
Gigabyte2
Gigabyte2
Bu ilke ayarı dosya adlarını sayısal olarak değil (Windows 2000 ve daha öncesinde olduğu gibi) metinsel olarak sıralamanıza izin verir.
Bu ilke ayarını etkinleştirirseniz, Windows Gezgini dosya adındaki her rakama bakarak (örneğin, 111 < 22 < 3) sıralar.
Bu ilke ayarını devre dışı bırakır veya yapılandırmazsanız, Windows Gezgini dosya adlarını artan sayısal değere göre (örneğin, 3 < 22 < 111) sıralar.
Çalıştıra gpedit.msc yazın. Çalıştırı açmak için kısa yol: Win+R tuşlarını kullanın.
Sonuç:
Önceki Hali:
Sonraki hali:
Uzun yoldan yapmadan direk registry kaydından yapmak için:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\{1B030A8A-B83A-4408-924A-DE55868BE687}Machine\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoStrCmpLogical"=dword:00000000
Resimde görüldüğü gibi sıralama düzelmiştir.
Yazan: Mendenn
sanırım registry kayıtları hatalı
Mendenn
Gigabyte2
Gigabyte2
Program bu değeri gösteriyor. Bugüne kadar aldığım değerlerde yanlışlık olmadı.
Ama önceden verilen değerlerle karşılaştırdığımda :
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies anahtarı altında Explorer ve ona bağlı
"NoStrCmpLogical"=dword:00000001 değeri yok.
ben az önce bendeki programla kayıtları yakaladım ve inan toplamda 52 registry kaydında değişiklik oluyor çok uzun olduğundan veremiyorum , ilaveten ilk verdiğin verdiğin registry kaydı hatalı , iç içe mi geçmiş nedir anlayamadım ayrıca ; "NoStrCmpLogical"=dword:00000001 değerini Microsoft veriyor verdiğim sayfanın kaynak kısmından görebilirsin (Hoş gerçi Microsoft önerilerinin %60 hiçbir işe yaramıyor ve bu olaydada bu doğrulandı sanıyorumki)
Mendenn
Gigabyte2
Gigabyte2
Denemesini de yaptım ayarı tekrar bozdum. Sonrada yakaladığım reg kaydını girdim. Sorun düzeldi.
işte reg kaydının yeri verdiğim adres ile aynı.
Mendenn yazdı:
üsttekini aynen kopyala bakalım hata vermeyecekmi
ilaveten :
verdiğim anasayfadaki kayıtlar doğru sadece kaynağa tıklasaydın kaydın Microsoft sayfasındaki anlatımında şu ifadeyi görecektin
Windows XP veya Windows Server 2003'te dosya ve klasörleri sıralamak için Windows 2000'deki yöntemi kullanmak istiyorsanız, Değer verisi kutusuna 1 yazın ve Tamam'ı tıklatın.
Windows 2000
Ie4_01
Ie4_128
Ie401sp2
Ie5
Ie501sp2
Ie6
Dosya ve klasörleri sıralamak için varsayılan Windows XP veya Windows Server 2003 yöntemini yapılandırmak istiyorsanız, Değer verisi kutusuna 0 yazın ve Tamam'ı tıklatın.
Windows Vista, Windows XP ve Windows Server 2003
Ie4_01
Ie4_128
Ie5
Ie6
Ie401sp2
Ie501sp2
kaynak : Anasayfadaki linkin Kaynak kısmı
Mendenn
Gigabyte2
Gigabyte2
Nasıl bir hata anladım ki?
-- Fix.reg gibi kayıt oluşturup tıklayıp girdiğimde hata vermiyor.
-- Adrese giderken hata veriyor mu diyorsan onda da hata vermiyor.
aynı yerdeki bendeki kayıt :
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\{86DF2F25-3A98-47A0-A633-E9D3FAC89F23}Machine\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
gördüğün gibi bambaşka değerler , sanırım her pc de ayrı oluşturuyor , ayrıca birçok yerde girdi oluştu
yani çıkan sonuç ; bende oluşan kayıt sende çalışmaz , sendeki de bende , denedim sendeki kayıt benim windows 7 ultimate x86 da işe yaramadı mesela , çalışmazdan kastım : Hiçbir değişikliğe neden olmaz , bu durumda sen de haklısın çünkü kayıt sende işe yarıyor , ama bende haklıyım bende işe yaramıyor :)
Mendenn
Gigabyte2
Gigabyte2
GUID (or UUID) is an acronym for 'Globally Unique Identifier' (or 'Universally Unique Identifier')
Türkçe karşılığı Genel Benzersiz Tanımlayıcıdır.
Guid’in açılımından da anlaşılacağı gibi kullanım amacı yapılan yada yaratılan nesneleri benzersiz hale getirmektir.
GUID (or UUID) : {86DF2F25-3A98-47A0-A633-E9D3FAC89F23}
Group Policy Objects den sonra gelen numara yani GUID değişiyor. öncesi ve sonrası aynı. O zaman sonrasına bakılacak :D ...
tasiyici
Megabyte3
Megabyte3
Kayıt: 23 Şub 2008, 19:26
Mesaj gönderen tasiyici »
yani hangi yöntemi uygulayalım tarkan abi ve mendenn abi
Mendenn
Gigabyte2
Gigabyte2
Önce Tarkan abi nin dediğini yap.
olmazsa
